4.3L starting issues need help
Old Feb 26, 2012 | 7:51 PM
bigj2201's Avatar
Default 4.3L starting issues need help
I have a 2003 silverado base model 4.3l v6 144xxx mi. Which has recently come into some starting issues this is what I've replaced so far
Fuel pump
Fuel filter
Fuel pressure regulator
I've cleaned my maf sensor I've also replaced my air filter...I thought for sure the regulator would of done it but I guess I was wrong if I want to start my car I have to hold the gas pedal in then crank on key??? Any help would be sweet
Old Feb 27, 2012 | 6:16 PM
Fishinfooleric10@aol.com's Avatar
well that just sucks. Here's a question after cranking on it, does it start and die, or if it does run is it shaky or missing or anything?
Old Feb 27, 2012 | 10:19 PM
bigj2201's Avatar
it starts if i press on the gas pedal then its gets shaky for about 5 seconds and then its fine till i shut it off and start it again
Old Mar 1, 2012 | 5:18 PM
Well, you might have a vacuum leak or also you can check your throttle body to make sure its not all nasty and stuff in there, but it seems like the hard starting would be due to a vacuum leak. Sorry i dont have more help
Old Mar 25, 2012 | 11:54 AM
dandelli's Avatar
New User
Awaiting E-mail Confirmation
Default v6 starting issues
Has anyone out there had any issues with starting a silverdo v6 after doing a lower intake gasket? The timing is correct,there are only two ppsistions for the distributor to drop and the oposite side drop will not even crank. There is a funky car lock symbol that is coming on the dash after 7 or 8 cranks. Any help please?
ironhead1974
Feb 22, 2020 10:03 AM
sabinandmary
Feb 21, 2012 10:55 AM
jeffwest5599
Jan 5, 2008 11:09 PM
99 on dubs
Dec 29, 2007 12:17 AM
