4 wheel drive binding going straight
Old Mar 25, 2013 | 9:51 PM
raspy87's Avatar
Default 4 wheel drive binding going straight
Hey I have a 2006 1500 silverado with push button four wheel drive. When I put it in 4 hi and try to drive it acts as if the front diff is binding up. Then when I put the transmission in neutral and put the t case in 2 hi the truck jumps and makes a big clunk. Also the t case makes a squealing noise in 4 wheel drive when you lift it up on a hoist and turn the rear drive shaft. Is it something in the t case causing all this or a combination of both? Any input would be much appreciated. By the way I only have to move about 20 feet to get it to bind up going straight no turns. Thanks y'all.
Old Mar 25, 2013 | 9:54 PM
streched chain in the t-case?
Old Mar 26, 2013 | 5:43 AM
Allan In NE's Avatar
Different tire sizes front to rear?
Allan
Old Mar 26, 2013 | 7:03 AM
raspy87's Avatar
Same size tires but different brands. Is it because of different diameters causing it? The fronts are Coopers and the backs are bridgestone.
Old Mar 26, 2013 | 7:05 AM
raspy87's Avatar
I bought the truck back in September and have only actually used the auto 4wd in a snow storm one night.
Old Mar 26, 2013 | 8:02 AM
Yes,
Get it up on all fours and measure the diameter of the tires. Doesn't take much difference front to back (an inch) and it'll bind like crazy.
Allan
Old Mar 26, 2013 | 9:20 AM
raspy87's Avatar
Ok so I need new tires then lol. Now what of the squealing from the transfer case when its in 4 hi and I turn the rear drive shaft by hand?
Old Mar 26, 2013 | 10:34 AM
ToooTall1's Avatar
Default Noise
Check the oil in the transfer case. Electronic push button take Auto-Trak II blue fluid. Hand shift take regular tx fluid.
Old Mar 26, 2013 | 10:45 AM
That is not the transfer case making that noise. It is the low overun clutch in the back of the transmission settin' up that 'squealing' noise. Normal.
Allan
Old Mar 27, 2013 | 6:15 AM
raspy87's Avatar
Ok thank you very much!
Billy HC
Dec 10, 2018 1:59 AM
Jaysonic
Mar 8, 2010 9:07 PM
jchcomputers
Aug 8, 2009 12:01 AM
SuperTexan
10
Oct 8, 2007 11:53 PM
02blue1
Sep 4, 2007 10:59 PM
