4 Wheel Drive Problems
Old Jan 1, 2011 | 8:44 AM
dleesco's Avatar
Default 4 Wheel Drive Problems
Having trouble with push button 4 wheel drive, Push 4x4 hi button all it does is flash 5 times . I hear the actuator motor in the transfer case but does not seem to engage .Could it still be the actuator ? Could it be the one in the front axle ? Do not think its the axle one since it is not engaging at the transfer case .Anyone have any ideas where i should start?
Thanks
Old Jan 1, 2011 | 11:52 AM
CJ_Tiz's Avatar
What year truck? There has been several post on the early 2000 models already. With 4wd issues. My truck has the same issue.
Old Jan 1, 2011 | 12:03 PM
ToooTall1's Avatar
Start with grounding wires under drivers door outside frame looking forward. Clean untill all have bare metal, then tighten securely. Clean all connectors on T/C, forward axle and dash switch. Had same problem but once all cleaned problems went away. Good Luck
Billy HC
Dec 10, 2018 1:59 AM
chris4735
18
Jan 29, 2015 4:30 PM
bob4444
Jan 10, 2011 4:10 PM
dleesco
Jan 8, 2011 8:36 PM
Jaysonic
Mar 8, 2010 9:07 PM
