4 wheel drive wont engage
Old Jan 18, 2010 | 3:55 PM
Keith Ries's Avatar
Default 4 wheel drive wont engage
The differential is not engaging and the light on the floor board does not come on when I shift into 4WD on my 1989 silverado. There are two sets of wiring harnesses going into the differential. The upper has 3 wires and the one on the bottom has 2. I checked the fuse and its fine. Do both sets of wires go to solonoids inside the differential?
Old Jan 18, 2010 | 5:25 PM
mudmaniac's Avatar
Ride of the Month
May 2009
The 2 wire connection is power to the actuator, the 3 wire goes to a contact switch that turns the light on. Check for power on the 2 wire when you have it shifted into 4wd, remember to drive a little after you shift to give it a chance to engage.
Old Jan 18, 2010 | 6:09 PM
RockyS.'s Avatar
Had the same problem on my '95 Z71. Had to replace the actuator wire harness. Hope this helps.
Old Jan 21, 2010 | 12:50 AM
88chevdream's Avatar
I just had the same thing happen to my 88 and had to replace the actuator. The light in the cab can take up to 30 seconds to kick on so be patient
Old Jan 21, 2010 | 8:14 AM
bwaterfowler15's Avatar
yea im having the same issue with my 95 z71. the light in the cab comes on when i put it in 4low and 4high, but only 4 high works. pretty sure its the actuator.
Old Sep 10, 2014 | 3:14 PM
Donno21's Avatar
'88 1500 4 wd pickup. New actuator, still no 4wd. Is there or where is the fuse located?
Billy HC
Dec 10, 2018 1:59 AM
kerusm
Feb 10, 2012 5:58 AM
dylan13
Apr 13, 2011 7:52 PM
Jaysonic
Mar 8, 2010 9:07 PM
98ch3vy
Nov 17, 2008 10:59 PM
