4 wheel problem
Old Aug 27, 2012 | 12:37 AM
cperry2704's Avatar
Default 4 wheel problem
i just bought a 2005 silverado z71 and they push button 4x4 switch panel has no power going to it from what i can tell, no lights come on at all, only had the truck a week...common problem?
Old Aug 27, 2012 | 1:16 AM
jesse06's Avatar
not too sure on the 2000+ but on an older one that'd be your 4wd seliniod most likely
Old Aug 27, 2012 | 10:03 AM
cperry2704's Avatar
oh ok, yea im new to all this, i had it plugged in to see if it threw any codes, and nothing showed
Old Aug 27, 2012 | 12:26 PM
kevinkpk's Avatar
Do you have a service 4wd? My 2000 had an issue with the switch itself.
Old Aug 27, 2012 | 2:33 PM
cperry2704's Avatar
nope nothing at all...no service lights, no codes, could is be a sensor or fuse not transmitting signal to computer?
Old Aug 27, 2012 | 9:19 PM
MDTAHOE's Avatar
Professional Mechanic
You can not scan the transfer case computer which a generic code reader. You can only scan the powertrain. Most auto part stores can not scan it either.
Old Aug 27, 2012 | 9:22 PM
maxxman04's Avatar
very true. i would check fuses, and if all are good, trace wiring, looking for breaks, shorts. could be too that the lights on switch itself aren't working.
Old Aug 28, 2012 | 9:36 AM
cperry2704's Avatar
thanks for the help, going to dig into her this week and see what i can find
Old Sep 5, 2012 | 1:29 AM
kerry1shah's Avatar
Hello
In my car there is a problem of low break.
have you any solution for that?
82LiftedChevy
Sep 25, 2013 8:50 PM
schuey59
Apr 10, 2012 1:38 AM
Teton
Oct 2, 2011 10:13 AM
Jaysonic
Mar 8, 2010 9:07 PM
subirs05
Aug 7, 2008 12:44 AM
