Brake problem
Old Aug 11, 2012 | 12:32 AM
ETSA Miller's Avatar
Default Brake problem
When I hit my brakes, when I'm almost completely stopped, I get this bad vibration in the brake pedal and the brakes either weaken or pull to the left. Anybody know what this is? It has brand new shoes and rotors.
Old Aug 11, 2012 | 1:57 PM
year, model, 1500, 2500??
new brakes front and rear? rear disc or dums?
if new drums; I bet you bought aftermarket.
If we install aftermarket drums on a chevy p/u; we always machine new drums cause they're junk...typically out 0.007" new
Old Aug 11, 2012 | 5:11 PM
spyncycle's Avatar
Sounds like the left caliper is sticking. The bolts weren't lubed.
Old Aug 11, 2012 | 5:31 PM
kevinkpk's Avatar
Calipers have been known to lockup. This wouldn't be near the first one to do so.
Old Aug 11, 2012 | 7:13 PM
for the pull yep...could also be drums not set up equally or one side star wheel adjuster seized or not working.
if i only knew the brake set-up the truck has!!
Old Aug 11, 2012 | 7:43 PM
kevinkpk's Avatar
He stated new rotors, I assume disc.
Old Aug 12, 2012 | 8:16 AM
Alright, its disk brakes all around. I didnt mess with the back ones because naturally the front one wear faster. But the front has new brakes and rotors. The abs light is also on i just noticed.
Old Aug 12, 2012 | 8:54 AM
Did you replace the ABS sensors? Mine did exactly that and it was a bad ABS sensor. Don't buy the real cheap ones because that's what they are, real cheap and don't work right.
Old Sep 5, 2012 | 1:37 AM
kerry1shah's Avatar
Hello
In my car there is problem of low break.
Please suggest me some idea.
Slobby Baymon
Nov 12, 2013 11:52 PM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
tom5170
Mar 19, 2010 11:57 PM
