496 8.1 Lower Head Bolts Leak
Old May 17, 2009 | 12:14 PM
SDFever's Avatar
Default 496 8.1 Lower Head Bolts Leak
Hi,
I have an 03 496 8.1 engine. Once you take the heads off and replace it is seemingly impossible to get a couple of the "lower" head bolts to stop leaking antifreeze... Drives me flippin' nutz at it sits in my boat with an all white engine compartment.
1. It does NOT leak with a pressure tester set at 16LBS over night.
2. I've used the GM brand brown sealant (seems like good sfuff).
3. Tried Permatex
4. Still using fresh Dexcool
Only leaks usually at higher rpms. Tried heavy coating of sealant on all threads, shank, and back side of hex part of bolts. Put sealant on both sides of stainless washer. Put some around the lip of the hole itself. Had it apart 4 times. This simple leak has out smarted me.
Jason@pacifictradesplus.com
760.522.0202
Many thanks to anyone who wants to hep me. If you're around San Diego Bay I'd be happy to take your for a fun ride any weekend.
DOBERDEWD
Dec 11, 2011 11:35 PM
chevyguy777
Oct 28, 2011 5:02 PM
SDFever
May 18, 2009 10:34 AM
