4l60e whine
Old Mar 23, 2011 | 3:56 AM
zakman's Avatar
Default 4l60e whine
i jsut put a 4l60e in my 97 and i got everything hooked up got it running and it whined so i shut it right off checked sum things and found out there was no fluid on the dipstick so i put fluid in a qt at a time fired it up real quick and checked it till it showed on the stick then i started workin it through the gears till it showed a steady level but after all that it took about 9 qts it still whined but not as bad but still there i took it for a drive around the block and when i pulled it in the shop the whine went away idk what caused the whine (ie the pump or whatever else is in an auto i only know 5 spds) but do you think i did any damage?
Indianaman
Apr 20, 2022 6:23 AM
randyehughes
Sep 29, 2019 9:58 PM
shaff23
Apr 19, 2015 11:43 AM
abqgolfer
Aug 27, 2011 11:30 PM
randyehughes
Jun 7, 2006 5:56 PM
