4L80E Overdrive Shifting
The 4L80E in my 97 2500 Silverado occasionally will not readily shift into overdrive and will sit in third on straight level highway unless I either give the throttle a quick prod or the truck goes down a slight downhill slope that it will shift into OD. Otherwise the tranny shifts smooth and quiet. Any idea what the problem could be? I just had the tranny flushed and filter changed, but it was doing it before that too.
Thanks in advance.
Thanks in advance.
Nope. Truck is bone stock other than a K&N. If it was an older model I'd say it would have something to do with vacuum pressure. It seems to shift into OD ok when little or no torque is being applied.
snake91876
October 13th, 2012 3:41 PM
