4x4 issue
Old Feb 15, 2011 | 10:46 AM
sollucho's Avatar
Default 4x4 issue
So my 4x4 went out a few weeks ago while in the mountains and I just got around to trying to fix it. I thought it was the actuator but after $100 the problem has not been fixed. The transfer case seems to go in because I can hear it "grind" on occasion but the light on the floor shifter is out. The next thing I will check is the transfer case switch and the fuse. Now I look for the fuse under the hood and did not find anything that said 4wd and I don’t seem to have fuses under the dash, can anyone help with any suggestions? Thanks!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Feb 15, 2011 | 11:22 AM
gotstylez's Avatar
what year/model
Old Feb 15, 2011 | 11:25 AM
sollucho's Avatar
Sorry, 1995 Silverado 5.7, 5 speed.
Old Feb 15, 2011 | 11:27 AM
gotstylez's Avatar
put in 4wd..either high or low.. crawl under and see if the front driveshaft turns...this iwll rule out the transfer case.. it should not turn..most likly something in the front end..
Old Feb 15, 2011 | 11:30 AM
sollucho's Avatar
Will do. Do you know where the 4x4 fuse is? Thanks for your input!
Old Feb 15, 2011 | 11:32 AM
gotstylez's Avatar
when you open the driver door there is a fusebox....and also under the hood there is another fuse box.. not sure which would have it.. both have everthing listed..
Old Feb 15, 2011 | 11:37 AM
sollucho's Avatar
okay, must be in the door as the one under the hood shows no 4x4. Thanks, I will post what I find
Old Feb 15, 2011 | 12:03 PM
sollucho's Avatar
Well I feel like a fool..it was a blown fuse. However that brings me to wonder why the fuse would have blown, any clue? Really just happy I have 4x4 again!
pontiacnut
May 7, 2011 1:26 PM
technicauto
May 4, 2011 5:14 PM
chevyman1978
May 1, 2008 6:41 AM
cowboyfromhell
Jun 5, 2007 9:31 AM
partsfor24
Apr 18, 2007 3:55 AM
