6" Lift Tire Size
Old Feb 14, 2010 | 10:06 PM
mc1040's Avatar
Default 6" Lift Tire Size
A 91 silverado with a 6" rough country suspension lift. How wide of 35" tires can you put on it? It says 35" x 12 1/2" wide is ideal for this application, can you go 14 1/2" wide without rubbing?
Old Feb 14, 2010 | 10:10 PM
maxxman04's Avatar
depends on the backspace of the wheels. you will probably need a wheel with more negative offset. and possibly a wider wheel, like 10" or so wide. if this truck is street driven, you may need fender flares as well, to be street legal. check with local laws about that.
Old Feb 14, 2010 | 10:20 PM
UH60sSuck's Avatar
I would go with a 12.50 on a 10" wide rim with atleast 4.5" backspace. Should kick your tires out enough so there is only minor rubbing that can be trimmed up really fast. Plus your supposed to go with around a 2" size difference between tire and rim. So if you went with a 14.50 tire you would be looking at wide rim or would be wearing the inside of your tires alot faster.
Old Feb 14, 2010 | 11:11 PM
gotstylez's Avatar
go here https://chevroletforum.com/forum/tahoe-suburban-25/wheel-tire-chart-how-big-can-you-go-29798/ and click the link.. it will tell u the max tire size and everything for you truck with a lift
Acop305
Apr 27, 2011 9:05 AM
thunderace31
21
Aug 23, 2010 7:41 AM
tutt00
Jul 29, 2010 2:37 AM
chevyman323
Jul 16, 2010 11:56 AM
