Notices
79 K5 brake light issues
Old May 27th, 2009, 11:02 PM
Ride of the Month
September 2009
mike79K5's Avatar
Default 79 K5 brake light issues
my brake lights stay light even if the truck is off. anyone know what might cause this?
Old May 28th, 2009, 7:15 AM
racerx55's Avatar
there is a switch ( more like a button) that your brake pedal pushes when its up to turn off the lights, it right under the dash at the top of the pedal.
alot of times the threads that hold it in place wear out because theyre plastic and it will slip back through the hole not allowing the pedal arm to touch it, or the pedal bushings wear down and you may be able to simply readjust the switch so its touching again.
Old May 28th, 2009, 9:44 PM
lukemoore646's Avatar
or the switch shot the craps
Old May 28th, 2009, 10:05 PM
Ride of the Month
September 2009
mike79K5's Avatar
thanks i'll give it another look. kinda hard, i already rhino lined the interrior...
Old May 29th, 2009, 7:42 PM
if you rhino lined under the dash i would think it would actually hold the switch into place, but that also may be your problem
justmike
January 17th, 2014 10:10 PM
stevenf
May 6th, 2013 11:41 AM
baldwincole
January 7th, 2012 7:00 PM
beckya99
July 12th, 2011 12:29 PM
ricky
February 4th, 2011 6:50 PM
Quick Reply: 79 K5 brake light issues
