'88 silverado flunks TX NOx emissions test
Old Aug 7, 2008 | 3:35 PM
migrox's Avatar
Default '88 silverado flunks TX NOx emissions test
My friend in SE Texas just failed to get his inspection sticker b/c of high NOx (oxides of nitrogen). He is disabled but able to do a little mechanical work. He passed last year easily. Truck has new oil change, new filters, new pcv valve, new plugs, and new half-*** $40 autozone plug wires. He swears it runs smooth, burns rubber, and idles smooth. He got it nice and hot before going to inspection station including flooring it a bit. 1)Anyone have any ideas on what to check? 2)I was thinking bad EGR valve or bad TBI bottom manifold gasket. Or else, both of those with a lazy O2 sensor and those half-*** wires. Any advice appreciated. Thanks,Michael
Old Aug 10, 2008 | 8:22 PM
shawnvw's Avatar
Banned
Default RE: '88 silverado flunks TX NOx emissions test
Failing on NOx usually indicates a temp problem. First thing i would look at is the EGR. It is designed to cool the combustion chamber. If that checks out ok,and it isn't overheating, you might want to look at the converter. If it has the original converter on it, its probably only a 2 stage. You can get a 3 stage converter that will help reduce NOx
codeman061988
May 20, 2014 11:15 AM
JCC
Oct 2, 2013 11:48 AM
Otown
Sep 20, 2010 3:10 PM
Heinousacts
Feb 9, 2010 1:44 PM
