'90 Silverado 1500 5.7v8 4x4 differential oil??
Old Aug 18, 2009 | 5:59 AM
zirk's Avatar
Question '90 Silverado 1500 5.7v8 4x4 differential oil??
Hi guys new to this forum! Bought this truck about two weeks ago, replaced all filters and oils with new ones. Next I want to replace differential oils. Firstly I am curious about what type of differential is in the truck(original)? Does it have a limited slip or not? Same oil for front and rear? Any advice would be much appreciated!!
Old Aug 18, 2009 | 10:13 AM
myotherchevyisablazer's Avatar
welcome,you should have a 10 bolt out back....(uses sae 80w90)
the front should be a split ifs case(can use the same grade)
you would have to look at your rpo list in the glove box which gives codes for parts that came stock on your ride.the rear is probally a limited slip...to check and see if it's limited slip...If you can raise both rear wheels, then turn one by hand, watch the other one. If it turns in the same direction it's a LSD, otherwise it'll go the opposite way.
Old Aug 18, 2009 | 12:50 PM
zirk's Avatar
Awesome info thanks!! One last thing "sae 80W90" is that a synthetic oil or not? Read somewhere that you have to use synthetic if you have a LSD. Oil depot in my area stocks a semi synthetic too.
Old Aug 18, 2009 | 1:09 PM
no it's not...you can run synthetic your choice ..better gear oil never hurt anyone you can try lucas oil....my oil choice is amsoil(very pricey)but love the results....did you test your rear to see if you had limited slip? yeah they say run special oil in the rear equiped limited slip...you should have a tag letting you know on the rear..well some do
xavier
Oct 24, 2012 10:54 AM
DGorris
Oct 6, 2011 11:20 AM
Greenroyd
Nov 9, 2010 6:30 PM
dcoperator
Mar 21, 2009 6:56 PM
Tex Avery
Nov 9, 2006 1:53 AM
