91 tranny issues
Old Apr 2, 2010 | 7:13 PM
efxtruck's Avatar
Default 91 tranny issues
my 700r4 is now officially shot....... I was wondering if a tranny form a 1986 454 would work on my 5.7L 350
Old Apr 2, 2010 | 7:21 PM
maxxman04's Avatar
it'll bolt on. it probably won't be a 700r4, it'll be th400 more than likely. if your 91 is 4wd, then the trans off 454 must be 4wd as well, 2wd must be 2wd.
Old Apr 2, 2010 | 7:30 PM
efxtruck's Avatar
Yeah they r both 4wd. Is the th400 a stronger tranny??
Old Apr 2, 2010 | 7:59 PM
maxxman04's Avatar
a little bit, but it's also a power eater. the 400 is only a three speed, no 4th gear o/d. if you want strength over some economy, 400 will do.
Old Apr 2, 2010 | 8:15 PM
efxtruck's Avatar
I was told that it has o/d on the 454 tranny its from a 86 surburban so it should be a TBI system and Ive heard that some of them came with a 700r4..
Im looking for anything that will work really my truck has been parked for a while now I thought it was the rear end gears so I got them and they are in really nice shape and while i was changing them I found out it was the tranny.
Old Apr 2, 2010 | 8:18 PM
maxxman04's Avatar
it is certainly possible that it's a 700r4. if it is, it's the same as the 91 700r4. gm's bolt pattern is the same on all v8's.
Old Apr 2, 2010 | 8:19 PM
efxtruck's Avatar
well fingers crossed lol r the bolt patters the same for the big blocks and the small blocks
Old Apr 3, 2010 | 4:29 PM
nauticstar87's Avatar
The bolt patterns are teh same for BBCs, and SBCs.
Old Apr 9, 2010 | 3:54 PM
efxtruck's Avatar
is it possible to use a 700r4 from a blazer in a 1500???? Im thinking so but I'm not to sure.
Old Apr 9, 2010 | 4:32 PM
cudablack2004's Avatar
or swap a t56 in it! heavy duty trans with 6 gears! unless ur not into the manual trans!
