'94 305 TBI 1500 No Spark Changed Everything
Old Nov 3, 2011 | 10:28 PM
idorace's Avatar
Default '94 305 TBI 1500 No Spark Changed Everything
I have a Chevy 1500 305 TBI with intermittent spark. It starts when it wants to. I changed the plugs, wires, module, cap, rotor, and coil. No codes, it always cranks. I'm lost.
Jeff
Old Nov 3, 2011 | 11:00 PM
maxxman04's Avatar
what about the pickup coil inside the distributor? its the part with two wire, usually green and white, or green and yellow. goes around dist shaft. possibly fuses? do you have power to coil?
Old Nov 3, 2011 | 11:29 PM
idorace's Avatar
I call the the ignition module, changed. I will check to see if there is power to the coil.
Old Nov 3, 2011 | 11:40 PM
maxxman04's Avatar
ignition module and pickup coil are two different parts. the pickup sits inside distributor around the shaft. the ignition module mounts along edge, with two harnesses coming out.
korelabs
19
Nov 9, 2022 10:04 AM
mdm6713
May 23, 2022 7:41 AM
insane
Nov 3, 2013 4:22 PM
caj600ho
Aug 26, 2008 11:44 AM
teamtexas
Aug 14, 2008 5:31 PM
