'94 Z71 smokes up cab when put in 4x4
Old Jul 20, 2011 | 4:33 PM
nrbukowski's Avatar
Default '94 Z71 smokes up cab when put in 4x4
As the title states...when i put my '94 z71 into 4 low or high it starts smoking. I can see it come into the cab from the steering column as well as watch it roll up from under the hood by the windshield. Any thoughts on what the cause might be?
Old Jul 21, 2011 | 9:45 AM
GM Fixer's Avatar
weird... are you driving at this time? As you know where there is smoke... usually there is fire. My guess would be check fuse block under the hood for melted wires and in dash harness.
Old Jul 21, 2011 | 10:50 PM
Mille Racer 69's Avatar
What if you just put it into 4 and let it sit. Keeping it in park
does it still smoke?
Is it white, bluish, or black smoke?
Old Jul 22, 2011 | 9:56 AM
OLD WRENCH's Avatar
I beleive the 4wd is electrically controlled,probably a solenoid burning up. These give a lot of trouble.
Old Jul 22, 2011 | 9:22 PM
Pyles2330's Avatar
Is there any smell, If so try pulling the fuse to the 4x4 system. If there is a short then pulling the fuse should eliminate the problem,and the smoke.
maxxman04
Mar 1, 2017 9:54 PM
mikeymike
Apr 9, 2012 6:48 AM
cva59
Nov 29, 2010 1:54 PM
Paul Seidman
Avalanche
Aug 18, 2010 3:33 PM
mryan_davis
Aug 29, 2009 11:40 AM
