95 1500 Binding or grinding - Trannsfer Case?
I have a binding or grinding coming from my front Diff or transfer case. It shakes the whole dash in the truck and sounds like something is trying to engage or disengage. It seems more on the right hand side....it makes the truck undriveable. Even happens in a straight line in 2wd (less than 5 MPH) and seems to only happen when going forward and not right from a takeoff, after driving 50 feet. The truck sat for a few months and I hap to put it in 4wd to get it out of where it was parked. Could this be an actuator or maybe a CV shaft (RH boot looks ripped)
grab ahold of the cv shaft and see if it has any slop, play, unnessesary movement, then just replace it anyway because you dont want it to go out when you need it the most
dmitschke
September 19th, 2011 5:50 PM
WychDoctorGeorge
February 1st, 2011 7:45 AM
SuperTexan
10
October 8th, 2007 11:53 PM
