95 1500 fuel regulator options needed
Old Sep 6, 2012 | 10:05 AM
Rado95's Avatar
Default 95 1500 fuel regulator options needed
Looking to upgrade fuel regulator. Any recommendations? Adjustable type?Adding spacer soon.
Old Sep 6, 2012 | 11:25 AM
chevyboy1993's Avatar
i've seen many adjustables ones online but never bought any. jet has one. i just did a spacer on the regulator spring but the only problem is, tbi's only run around 10-13 psi stock and the stock fuel pump maxes out at 15 so if you wanna go higher than that you need an upgraded fuel pump also
Old Sep 7, 2012 | 9:20 AM
Rado95's Avatar
Thanks for the reply. Read somewhere that a spacer might need the 13 psi.
Old Sep 7, 2012 | 10:31 PM
i'm running the full 15 psi in my truck right now. had a different fuel pump before but it burnt out so i had to put the stock back in. with the aftermarket fuel pump i was running 24 psi using a 1/4" worth of washers. ran like a raped ape
solerano
Sep 1, 2013 5:26 PM
Tahoe Joe
Aug 16, 2009 4:48 PM
momto5
Jan 5, 2007 10:16 AM
momto5
Jan 4, 2007 10:46 PM
97metro
Aug 12, 2006 11:02 PM
