95 truck ; running lights
Old Feb 14, 2011 | 2:50 PM
s christy's Avatar
Default 95 truck ; running lights
my 95 1/2 ton has brake , turn and hazard lights but no running lights. Ive replaced the tail light units and bulbs, headlight switch and fuses.?
Old Feb 15, 2011 | 2:15 AM
s34n's Avatar
check the bulbs as well. check the connection at the bulbs as well. check for broken wires as well.
Old Feb 15, 2011 | 7:45 AM
s christy's Avatar
thanks, everything is new back there. looking at the wires now.
Old Feb 16, 2011 | 10:17 PM
RacerX's Avatar
Running lights or Parking lights?
Old Feb 16, 2011 | 10:36 PM
gotstylez's Avatar
95 doesnt have running lights.. im guessing parking light slike racer said
Old Feb 17, 2011 | 3:22 AM
sheldon 97suburban's Avatar
check your switch in the dash board, pull the cover off and press all the wires into your switch firmly and see if that fixes it, if it dose you might have a crunchy wire, i had the same problem after i tapped into my running lights for led cab floor lights i installed, i was on a trail and my dash and running lights all just shut off i popped the cover off thinking my tap into my running lights was to blame, and it was the connection in the switch box the wire was coming out just a simple press back in everything worked. so wires to the switch or the switch its self
Old Feb 17, 2011 | 7:48 AM
RacerX's Avatar
You should have ran an alternate switch for that. These trucks come with many detachable panels for extra switches. Also the fuse panel has many add ons and grounds blocks.
If it is the parking lights I suspect the headlight switch. If it the running lights, aftermarket you gotta fault trace. Maybe a fuse, relay or bad power or ground wire.
Old Feb 18, 2011 | 9:41 PM
i do have an second switch so they only turn on when i have the park lights on. and they are LED lights so hardly a power draw
RitualJman
15
Apr 22, 2026 9:15 PM
Stenny
Feb 12, 2015 11:07 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
skdevore
Aug 26, 2009 10:18 PM
Big_Jazzer
Feb 27, 2009 1:25 PM
