95 Z71 drive train component question
Old Apr 27, 2009 | 10:28 AM
mygreenihc's Avatar
Default 95 Z71 drive train component question
Hello guys,
My son bought his first vehicle over the weekend and I have a couple of questions for those of you who know more than me.
What is the best way to determine what drive train components are in this truck?
I need to determine which of the following components I have:
Transmission: 4L60-E or 4L80-E
Transfer case: NP241, NP243, BW4470, BW1370, or BW4401
Rear Diff: 8.5, 8.6, 9.5, or 10.5 ring gear
Does the torque converter on this model have a drain plug?
Thanks for your help
Old Apr 27, 2009 | 12:09 PM
bad2006z71's Avatar
look in the glove box at the rpo codes. check google, there are some sites on what the codes actually mean.
anyways 95 1/2 ton will be 8.5 ring gear 10 bolt rear, 4l60e trans, dont know on the transfer case. gears will either be 3.42 or 3.73 most likely. gt4 code= 3.73, gu6= 3.42, and gt5= 4.10.
good luck
Old Apr 27, 2009 | 2:41 PM
therewolf's Avatar
A 4L60E tranny has a drain plug on the pan. A 4L80E does not have a plug.
Generally the 1500(1/2 ton) has the 4L60E. The Z71 has a posi-rear, as per the last poster's notes, check that same "Service Parts Identification " sticker inside the glovebox for that "Z71" code. Then you can start narrowing it down from there.
Old Apr 27, 2009 | 4:49 PM
suzuki-guy's Avatar
The service sticker is actually on the drivers door it should have an auburn 8.5 inch 10 polt possi
Old Apr 27, 2009 | 6:54 PM
mudmaniac's Avatar
Ride of the Month
May 2009
The transfer case should be the NP241
Old Apr 27, 2009 | 7:16 PM
MDTAHOE's Avatar
Professional Mechanic
call the dealer with the vin # they will answer questions
Old Apr 27, 2009 | 8:15 PM
mygreenihc's Avatar
Thanks for the tips guys,
So far I have figured out that it has an NP241C transfer case from the tag on the TC. From the RPO codes, I determined for sure that it has a 4L60E tranny, an LSD, and 3.42 diffs. What I don't see is the Z71 code. I assume that it would be on this SPI label as well. If the truck has a LSD, would that indicate Z71?
Also, does the torque convertor on a 4L60E have a drain plug?
Old Apr 28, 2009 | 7:18 AM
bad2006z71's Avatar
no, G80 is the code for the locking diff. and the z71 package does not automatically come with a locking diff. z71 package is mainly shocks, skid plates, and stickers. if your rpo code does not say Z71 then you dont have the package.
good luck
Old Apr 28, 2009 | 10:11 PM
mygreenihc's Avatar
Wink
OK, that is what I thought. It definately does not have the Z71 RPO code, but it does have the stickers. For a 16 year old, that is really all that matters anyhow.
mountainlady
Oct 13, 2011 12:29 PM
MrJumpingBeans
Astro
Feb 11, 2011 6:17 AM
dalehughes
Jan 2, 2009 12:45 PM
hawkeye1734
Mar 11, 2008 6:11 PM
brims
Dec 8, 2006 2:28 PM
