'96 1500 High Oil Pressure Problems
Old Jan 20, 2014 | 3:04 PM
kb_1234's Avatar
Default '96 1500 High Oil Pressure Problems
Hi everyone, I need a little help and hope someone can answer my questions.
I have a 1996 chevy 1500 with the 4.3l engine. The oil pressure all of a sudden started running real high (80 psi+). It drops slightly when warmed up, but not that much. The pressure is so high it keeps blowing the gasket under the oil filter adapter.
I am thinking the relief valve has stuck shut. Has anyone ever experienced this? If so how did you resolve it?
Also where is the relief valve located? I can't seem to find any information on line about the relief valve itself.
Thanks in advanced for your help, I am getting sick of changing the gasket.
Old Jan 20, 2014 | 6:48 PM
Allan In NE's Avatar
Yep,
That's an odd one. Pressure regulator is in the oil pump.
Allan
Old Jan 21, 2014 | 9:07 AM
kb_1234's Avatar
Thanks Allan. Maybe I will just replace the pump and see if that fixes the problem.
Old Jan 21, 2014 | 9:38 AM
Before you do that, make darned sure that the oil pressure is actually high and not just a bad sender.
Allan
leppek11
Sep 23, 2015 10:39 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
eson
Aug 25, 2011 12:19 PM
ot01314
Apr 14, 2008 7:27 AM
Gymnutz
Mar 25, 2007 5:45 PM
