96 K2500 Cheyenne 4wd question
Old Jan 4, 2012 | 2:26 PM
k2500's Avatar
Default 96 K2500 Cheyenne 4wd question
The 4wd will go into 4wd high and back to 2wd. If I put it in 2nd gear on the column (its a automatic) I can get it into low. The 4wd isnt engaging im sure the transfer case is still good. The 4wd light in the floor is not lighting up so im guessing its something electrcial. Anyone else have this problem and did you replace the actuator or did you replace the transfer case motor?
I dont have a manual and just for reference am I correct in saying that the actuator slips inside the front differential on the passenger side and the transfer case motor rides on the back of the transfer case?
The Chevro
Nov 19, 2014 5:44 AM
CoreyB84
Jun 13, 2014 6:57 AM
phricard
Apr 15, 2013 1:03 PM
TPM
Mar 20, 2010 10:15 AM
jrsavoie
Feb 24, 2010 2:38 PM
