96 silverado 4x4= 6.5 diesel
Old May 30, 2010 | 11:29 AM
Gerald m's Avatar
Default 96 silverado 4x4= 6.5 diesel
when I engage the 4x4 (electric ) there is a gear clashing sound when I try to drive. I can hear the transfer case shift into 4 lo 0r 4 hi and I can feel a bit of a clunk when it goes into gear but it seems to slip on the gears when I drive. The over drive also makes a rattling sound when it shifts into overdrive when under some throttle load but stops when I ease up on the throttle. Overdrive will quit working and go to 3rd.if I keep on with the throttle down and the engine light will comes on . After sitting for a bit it will work again but will still persist with the rattling especially if I am pulling something like a trailer with a bit of weight on. any thoughts on these problems ? Gerald m
Old May 30, 2010 | 3:48 PM
gotstylez's Avatar
a good idea would be is next time it comes out to go advanced or auto zoone and get the CEL looked at..that would be a start so we can see what it says
Old May 31, 2010 | 9:34 PM
Gerald m's Avatar
what about the transfer case clashing these are two different things that happen at different times
Yes I will try to get a read out on the engine light . thanks Gerald
Old May 31, 2010 | 9:36 PM
gotstylez's Avatar
get under the truck and see if the front drive shaft will move after you put it into 4x4.. it it does then something is up with ur t-case.
Marcus Worth
Cruze
Jul 31, 2013 2:31 PM
ddd
Mar 19, 2013 8:39 PM
jacob.
Oct 10, 2012 7:31 AM
jrsavoie
Apr 23, 2011 9:22 AM
byoungquist
Aug 24, 2006 12:18 AM
