96 Silverado 5L missing
Old Nov 6, 2010 | 5:33 PM
deirulz011815's Avatar
Default 96 Silverado 5L missing
Hello everyone, I'm new here, hoping to get a bit of direction. Check engine light on so I pulled the codes and this is what I got: "P1345 camshaft to crankshaft position correlation fault" I tested the wires from both sensors, no breakes all is good there. I found out that each sensor should put out about 5 volts and I'm only getting about 2.5 from the crankshaft sensor and about 3.9 from the camshaft sensor. Should these be replaced or is there something else I should check first. Already changed the plugs, wires cap and button. The old plugs looked fairly normal. Not sure which cylinder is missing. Thanks.
Old Nov 14, 2010 | 12:38 PM
Has anyone else had this problem with the same code?
fox48
Apr 8, 2021 7:29 PM
93z71
Nov 24, 2012 5:19 AM
arm&wrench1088
Dec 24, 2010 6:38 AM
rustedduck
Oct 3, 2008 10:45 AM
cube4hire
May 17, 2007 5:10 PM
