97 1500 fuel filter 5.7
Old Aug 15, 2011 | 6:49 PM
jadwinmo's Avatar
Default 97 1500 fuel filter 5.7
Man, I am trying to remove this fuel filter, and I ain't havin any luck. Not sure if it is the original but the lines are very tight. I sprayed some wd40 on them and will let them sit. Any recommendations if this doest help? If you know the wrench sizes needed would also be helpful. Was using adjustable and would not hold.
Thanks Smitty
Old Aug 15, 2011 | 8:39 PM
MDTAHOE's Avatar
Professional Mechanic
The fuel line is 16mm depending on the filter it is 19mm-21mm. Get a can of PB blaster from the auto store it is far superior than WD-40.
Old Aug 15, 2011 | 8:53 PM
usmarine0905's Avatar
and get a "Line wrench" not an adjustable... you can twist the fuel lines if you are not careful with the adjustable....
Old Aug 15, 2011 | 9:45 PM
Mille Racer 69's Avatar
Lefty loosely righty tighty
Old Nov 5, 2020 | 2:58 PM
Mysifara's Avatar
Thanks Smitty
you need a 3/4 & 7/8. The bolts turn opposite directions.
Old Nov 5, 2020 | 3:20 PM
Mysifara's Avatar
Thanks Smitty
silverado 1500 2001
Sep 14, 2014 7:41 PM
DeHartShadow
Oct 22, 2013 10:52 AM
mshaw130
Jul 13, 2013 11:39 PM
blockerb
Nov 5, 2010 3:17 PM
MrPuzzlez
Jan 4, 2009 12:02 AM
