97 gmc trans swap now starts with the key in the on position
Old Mar 17, 2011 | 12:52 AM
zakman's Avatar
Default 97 gmc trans swap now starts with the key in the on position
i got a 97 gmc 1500 2wd with the 5.7 and 4l60e i just changed the trans cuz the forward drive clutch went and the new tranny didnt have a long enough shaft on it for the linkage to put the neutral safety switch box so i took it off the other trans with it in park and plugged it in so the truck would think its always in park so it would start but now the light on the dash says its in 3rd no matter what and when i turn the key to the on position the truck starts and the starter keeps spinning any ideas?
Old Apr 20, 2011 | 1:28 AM
archebald23's Avatar
I think that you may be needing some ideas if it is part of a gmc recalls that had happened before. If not, try to read up some resources that would be able to really make things work out for your vehicle. Try to figure it out.
mybadz71
Jul 9, 2022 9:31 PM
advcomps
Sep 18, 2013 10:22 AM
otacon28
Mar 11, 2007 1:32 AM
