97 silverado z71 5.7 Vortec
Old Jun 9, 2011 | 10:33 AM
mrcleanmom's Avatar
Exclamation HELP!! popping & backfire, starts great, irratic idle. 97 silverado z71 5.7 Vortec
I just bought a 1997 chevy z71 with vortec 350 its backfiring real bad. it cranks and starts fine though. i have changed plugs, wires, distributer and no change. I have checked the egr and pin 1&5 reads .01v and the pins 2&4 is reading 3,4v. I have checked the MAF, it seems good. I have no specific codes but cleared anyways. What flashes is the catalyst heat monitor, catalyst monitor and egr monitor. Im very mechanically inclined however this has me baffled. It popps and popps, sounds like its popping in the exhaust, the engine does not surge or misfire but occasionally lets out a huge gunshot like bang. prev owner said he blew out a cat baffle. I would usually just start replacing the sensors in a process of elimination but these sensors are pricey. codescould it possibly be a stuck valve and making it backfire through the intake? I'm at a stand still here.
Last edited by mrcleanmom; Jun 17, 2011 at 11:18 PM. Reason: title unclear so I included some symptoms so I can maximize help
Old Jun 9, 2011 | 1:04 PM
shamrock246's Avatar
i had a cap and rotor on mine cause starting problems it looked not to be made to spec replaced with AC/DELCO unit that did look to be made differently and it starts fine,old style cranck sensor also had problems,do a compression check
Sean
97 4x4 burb
Old Jun 9, 2011 | 10:15 PM
mrcleanmom's Avatar
Default 97 Silverado Z71 5.7 Vortec
I will try the compression test, i will check o2 sensors...... Cap is the one with the plug wires plugged into the side of cap. I will also check the crank sensor. Thanks.
Old Jun 17, 2011 | 8:46 PM
mrcleanmom's Avatar
Did compression test, 182 psi 13:1 on all 8 cylinders, checked ohms at pre-converter oxygen sensor and that was a 4.8 on both. Check fuel pressure and its 62 psi at key on engine off, but immediately looses pressure, this tells me it has a leak at one or more of the injectors. Engine running fuel pressure was a strong 55psi. Had to regap plugs and they were wet. The backfire is coming from the left bank only.
MedicAR
Mar 15, 2015 9:07 PM
ford with a chevy
Apr 11, 2013 1:37 PM
mrcleanmom
Jul 11, 2011 9:44 PM
jaxontipedeau
Feb 6, 2011 11:48 AM
yellow73bb
Jul 6, 2007 3:58 PM
