97 Siverado 5.7 Vortec running 'BAD'
Long story short....
Truck was running fine. Had just dropped over $600 in a tune up. Let a friend borrow it to go to the store. Hour later he comes walking up. Truck just died on him and won't start....have to have it towed home.
Turns out the rotor on the distributor came off while he was driving. Replace cap, rotor and sensor on distributor. Starts now but runs like crap. Starts fine, idles ok, but give it gas and it spits and sputters and can't rev it up all the way. Driving it gives same results. Replaced timing chain....no better.
So today I put it on a MatcoTools CAN400 OBD II Scan tool.
Matco Tools CAN400 OBD II Scan Tool RESULTS
I/M Monitors--------
Misfire Monitor Ok
Fuel System Mon Ok
Comp Component Ok
Catalyst inc
Htd Catalyst n/a
Evap System Mon n/a
Sec Air system n/a
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr Ok
EGR System Mon inc
CODES--------
P0340 Camshaft Position Sensor A Circuit (Bank 1 Or Single Sensor)
P1345 Crankshaft position / Camshaft position sensor correlation
P1345pd Crankshaft position / Camshaft position sensor correlation
Freeze Data------Key on engine off
P0340 (Mod $10)
Trouble code P0340
ABSLT TPS(%) 0.0
ENG Speed(RPM) 791
CALC Load(%) 6.7
MAF (LB/M) 1.95
MAP ("HG) 13.3
Coolant(F) 75
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH Speed(MPH) 0
Fuel SYS 1 Open
Fuel Sys 2 Open
Data-------Engine running
MIL Status On
ABSLT TPS(%) 0.0
Engine speed(RPM 750
CALC Load(%) 4.3
MAF (LB/M) Ranging 1.28 - 1.40
MAP ("HG) 11.5
Coolant (F) 124
IAT(F) 97
IGN ADV Ranging 19.0 - 24.0
ST FTRM1(%) -30.5
LT FTRM1(%) -18.0
ST FTRM2(%) -30.5
LT FTRM2(%) -18.0
VEH Speed 0
Fuel SYS 1 CLSD
Fuel SYS 2 CLSD
02S11(V) 0.830
ST FTRM11(%) -30.5
02S12 (V) 0.785
02S21 (V) 0.925
ST FTRM21 (%) -30.5
02S22 (V) 0.855
PTO Status Dise
OBD2 STAT CA
I'm no expert so can anyone tell me if they see anything in these results that I don't see....which isn't much....lol
Thankyou in advance for any and all help/info.
Misfire Monitor Ok
Fuel System Mon Ok
Comp Component Ok
Catalyst inc
Htd Catalyst n/a
Evap System Mon n/a
Sec Air system n/a
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr Ok
EGR System Mon inc
CODES--------
P0340 (Mod $10)
Trouble code P0340
ABSLT TPS(%) 0.0
ENG Speed(RPM) 791
CALC Load(%) 6.7
MAF (LB/M) 1.95
MAP ("HG) 13.3
Coolant(F) 75
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH Speed(MPH) 0
Fuel SYS 1 Open
Fuel Sys 2 Open
MIL Status On
ABSLT TPS(%) 0.0
CALC Load(%) 4.3
MAP ("HG) 11.5
Coolant (F) 124
IAT(F) 97
ST FTRM1(%) -30.5
LT FTRM1(%) -18.0
ST FTRM2(%) -30.5
LT FTRM2(%) -18.0
VEH Speed 0
Fuel SYS 1 CLSD
Fuel SYS 2 CLSD
02S11(V) 0.830
ST FTRM11(%) -30.5
02S12 (V) 0.785
02S21 (V) 0.925
ST FTRM21 (%) -30.5
02S22 (V) 0.855
PTO Status Dise
OBD2 STAT CA
ttown James Jones (December 20th, 2019)
Professional Mechanic
You need to have a scan tool that can read cam retard. It is the only way to see how far off the distributor is. The cam retard spec is 0 +or-. The cam sensor is the piece inside the dis you replaced. I would only use a part that came from the dealer for that. Many aftermarket primary ignition parts do not work.
Well, I can definetly get the cam sensor from the dealer. But the scan tool is another story. Just gonna have to put it in the shop to get the timing done as it will be much cheaper on me that way.
Chev_Hoe
January 14th, 2014 9:41 PM
beaver2low
November 24th, 2013 11:56 PM
Goofy
December 21st, 2010 5:45 AM
