97 Z71 steering locked
blew all the fluid out from somewhere? i filled it and it doesn't turn, its like its fighting me. The harder i try it growls and stops solid? what next?
Okay, i just had someone turn the wheel while i watched, the hi pressure line swells up about twice its diameter and the fluid does shoot out like a car wash nozzle's pressure. (very thin and fast) At this point ill be replacing that, but something must be blocked, no?
PS not hydro system
PS not hydro system
ok, if not a hydro system, then its easier. just replace the high and low hoses and completely flush out the old fluid. The old hoses (hi and low sides) will rot from the inside so they both need to be replaced. for the low side, just buy about 18 inches of ps hose and use hose clamps on the factory metal hose fittings.
When installing the new high side hose, use new orings and apply grease to the orings. if you tighten down the fittings to much, the orings will shred and you will have leaks.
cabinet
December 31st, 2010 1:44 PM
