98 k1500 missfire
Old Feb 20, 2013 | 6:07 PM
Joey Turner's Avatar
Default 98 k1500 missfire
I have 98 k1500 5.7L it has a missfire problem nobody can seem to find the cause including me any help would be appreciated!!! IT has a miss at idle and will stumble in gear when you first hit gas then runs fine up to highway speed once a steady speed it has a random miss\jerk..has plenty of power will not miss if you really gas on it..has been in every shop I know of and has had every sensor,dist cap,rotor,wires,plugs,cam sensor replaced no sel no codes Im so frustrated PLEASE HELP IF YOU HAVE ANY IDEAS
Old Feb 20, 2013 | 6:49 PM
kevinkpk's Avatar
Sounds like bad gas
Old Feb 20, 2013 | 6:58 PM
can't be bad gas its been doing this for 3 years
Old Feb 20, 2013 | 8:53 PM
kevinkpk's Avatar
Not being Merlin the mind reader, can you give more detail as in last tune up, plugs ect?
Old Feb 20, 2013 | 10:02 PM
tymr287's Avatar
Have you a compression test? That would rule out any internal problems.
Old Feb 21, 2013 | 6:57 AM
shamrock246's Avatar
Whats the fuel pressure?could be a poppet in the spider injector assy sticking they make an upgraded version that runs much better
ke5eme
Apr 10, 2013 10:18 PM
vroomvroomchevy
Jan 24, 2009 4:45 PM
dirtydime03
Dec 26, 2008 8:08 PM
vermena
Apr 11, 2007 3:31 AM
vermena
Apr 9, 2007 10:46 PM
