98 K1500 Z71 Power Window Problem
Old May 13, 2013 | 9:10 AM
jmullins0315's Avatar
Default 98 K1500 Z71 Power Window Problem
Ive had the truck a few weeks now. When i bought it the driver side window would roll down but had to mess with the switch quite a bit to get it to roll down. Now the driver window will not go down at all, but I can still control the passenger side window from the switch on the drivers side door??? Does this sound like my switch is bad or the motor in the driver window? I dont wanna just buy parts and change them without knowing what my problem is for sure. Thanks for any help
Old May 13, 2013 | 2:11 PM
kevinkpk's Avatar
Driver side window is used more than any others. Probably the motor. I've not looked at cost, but I'd say after market $25 or so? This model may require the regulator also, I just looked at Dorman, about 80 bucks for both. I don't know your location, but I'd check autozone, napa, O'rielleys
Old Jul 14, 2013 | 7:05 PM
Switch Doctor's Avatar
Default 98 Chevy Master Window Switch
Most places wont let you return anything electrical if it isn't the issue. However here at switch doctor you have a 30 day return policy and if the switch isn't the issue you can return it within the 30 days. http://www.switchdoctor.net
Old Jul 15, 2013 | 5:57 AM
kjohns's Avatar
New User
Awaiting E-mail Confirmation
Where else could I find info on this?
Old Mar 17, 2023 | 12:27 PM
goddardgirl178's Avatar
did you find a solution? I’m having the exact problem
justin69
Feb 28, 2015 2:54 PM
1994medtec
Jan 11, 2012 2:01 AM
davbell22602
Mar 10, 2010 8:36 PM
DrummerBoy
Oct 17, 2009 10:20 AM
3cylinder
Sep 3, 2006 7:21 AM
