98 Silverado Issues
Old Mar 10, 2011 | 7:17 PM
dcoperator's Avatar
Default 98 Silverado Issues
Please help..I have a 98 Silverado with a 5.7 Jasper engine w/20?k miles on engine and 110K miles on truck. As of late it developes sluggish engine issues over 40 mph and when warm it starts like it has hot timing. There has been a SEL on for sometime. I believe it has to do with the cat converter. However problem only seems to appear during wet conditions.Any help would be appreciated.
Old Mar 10, 2011 | 8:11 PM
loosebearing's Avatar
Check distributor for moisture. Could be converter stopping up.
Check front of converter how warm then feel after converter .. should be same temp.
If pipe in front gets hotter than after .. probably stopped up.
Old Mar 11, 2011 | 8:48 AM
OLD WRENCH's Avatar
Default missing
I would look for something breaking down in the ign. If you want to check conv. remove o2 sensor and check press. Shouldnt be over 3 lbs. approx.
Old Mar 11, 2011 | 12:26 PM
dcoperator's Avatar
What might be some of the things in the ignition to look for?
Old Mar 11, 2011 | 8:09 PM
RacerX's Avatar
whatever happened to checking the codes 1st?
Old Mar 12, 2011 | 6:42 AM
OLD WRENCH's Avatar
Default runs bad
You never heard "when all else fails read the directions" same here,and if you insist on this weird behavior we may have to recend your "mans union card"
Old Mar 12, 2011 | 10:19 PM
RacerX's Avatar
I m just saying, you know, if the car was built with OBD II for this specific purpose why should we guess?
Old Mar 13, 2011 | 11:56 AM
OLD WRENCH's Avatar
Default 98 Silvey
Of course you are correct. Back in my day they didnt have these things so I forget to mention this. Much the same reason that I got pulled over for not using my turn lights.
samsaridinc1500
Jan 10, 2014 9:12 PM
91 silverado
Oct 27, 2007 10:46 PM
WarrenK3500
Oct 24, 2007 7:05 PM
Chestah
Oct 19, 2006 10:21 PM
jjohn82
Jun 19, 2006 12:29 AM
