98 silverado squealing
Old Nov 16, 2009 | 2:33 PM
95 ss's Avatar
Default 98 silverado squealing
replaced ac compressor,belt,belt tensioner,idler pulley,alternator,water pump, still makes noise anyone have any thoughts?
Old Nov 16, 2009 | 2:43 PM
nauticstar87's Avatar
Power steering pump?
Old Nov 16, 2009 | 3:42 PM
95 ss's Avatar
i was thinking this or cleaning my pulleys off cause my buddy sprayed belt dressing on,or just forget it and replace power steering pump if so how hard is it?thanks
Old Nov 16, 2009 | 4:05 PM
Its not to bad. But if thats not whats squealing, it would be upsetting cause its a touch expensive.
Old Nov 16, 2009 | 8:58 PM
MDTAHOE's Avatar
Professional Mechanic
What size is the engine?
Old Apr 25, 2011 | 9:41 AM
waay2kul's Avatar
I also am having the same issue. I've replaced idler and tensioner pulleys, topped off the power steering, relatively new belt. During load it mostly goes away. It's loudest when idling or deceleration-only after about 10 miles. It doesnt squeal until then.
Old Apr 25, 2011 | 9:45 AM
waay2kul's Avatar
350 fuel injection, Full power, air, 4wd, Waldoch conversion Trailmaster lift
Old Apr 26, 2011 | 6:54 PM
Big Chuk's Avatar
If you have gotten any kind of oil or fluid on your "new" belt replace it. And clean all of your pullys before installing the new one. Drive belts have a habit of soaking up any fluid they come in contact with, making them slip. Also this may sound stupid but get a quality belt to insure good grip & proper size.
Old May 16, 2011 | 1:09 PM
waay2kul's Avatar
Update
I removed the drive belt from crankshaft and all pulleys. Started engine and the squeal was still there. I am assuming that the harmonic balancer is going out. I'm not looking forward to it, but I will check it out this weekend.
Old May 16, 2011 | 7:07 PM
Rez's Avatar
Rez
I have no idea if the harmonic balancer would be causing that noise or not, but if you do need to replace it, its not that bad. You can rent the tools (1 for removal, and 1 for installation) free from autozone. Should take a couple hours max.
dhoff024
Oct 28, 2014 2:57 PM
tlaura21
Jan 25, 2012 1:59 PM
judy may
Colorado
Feb 4, 2008 1:12 AM
hoytheld
Feb 6, 2007 8:55 AM
ButchA
Jan 8, 2007 7:00 PM
