98 Z71 v8 won't start
I have a 98 z71 that will not crank. It went dead pulling in the drieway. I replaced the fuel pump. I have over 60 psi at the top of the engine. It will run as long as I pour gas into the throttle body. What can I try next? I also replaced the regulator
RE: 98 Z71 v8 won't start
you said it runs with fuel in the throttle body? hmm. i was gonna suggest spark, if there was no spark, thencheck Crank Position Sensor on front of engine by harmonic damper.i could be way off base, dont know.
well are you sure the fuel pump is good? if you arent getting fuel past your filter to the tbi then youre pump is bad. but you said you have 60psi at the engine. so if it is getting fuel, then maybe starter, or one of your spark plugs may be bad....
PanamaJ
July 12th, 2011 8:28 AM
