99 4x4 does not work
Old Nov 25, 2008 | 12:45 PM
Easy994x4's Avatar
Default 99 4x4 does not work
I just purchased a 1999 silverado 2500 knowing the 4x4 has issues. The lights on the dash panel switches are intermittent and the switch does not seem to function. The panel says to service 4WD.
What are the common issues with the 99 4x4?
Where can I get a replacement dash switch?
Is there a way to pull the codes without having a machine or take it to a shop?
Aside from not going into 4wd everything seems to be fine.
Old Nov 25, 2008 | 6:15 PM
northey87's Avatar
Default RE: 99 4x4 does not work
Check the switch, its usually the problem. I believe you can get it at you local parts store, or check online.
Old Nov 25, 2008 | 9:21 PM
jkgray80's Avatar
Chances are they sold it b/c it needs a $600 shifter & not a $80 switch, sorry.
goyakpacking
May 9, 2015 7:51 PM
shant
Feb 23, 2011 9:08 PM
larbec7
Mar 21, 2008 8:19 PM
gooseneck
Oct 4, 2007 8:03 PM
Top
Follow Us
