2002 Tahoe keyless remote does not work
Old Oct 4, 2007 | 7:45 PM
gooseneck's Avatar
Default 2002 Tahoe keyless remote does not work
Changed vehicle battery and now the keyless remote does not work.
Old Oct 4, 2007 | 8:03 PM
John86's Avatar
Default RE: 2002 Tahoe keyless remote does not work
do ur locks work properly? if so sounds like u need to reprogram ur key fobs. try this
[ol]Transmitter Programming Procedure (Method 1 - No Tools Required)
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation. [/ol]
goyakpacking
May 9, 2015 7:51 PM
indoorairpro
Jul 25, 2014 6:03 PM
shant
Feb 23, 2011 9:08 PM
apb
Dec 15, 2010 12:48 PM
igud
Jan 22, 2010 5:00 PM
