99 Silverado A/C issues
Old Jul 4, 2012 | 2:28 PM
jd2350's Avatar
Default 99 Silverado A/C issues
Air coming from vents is not as cold as it should be and there's not as much volume as there should be either. Cabin filter has been changed and all duct work seems to be intact. Any suggestions?
Old Jul 5, 2012 | 11:19 AM
See if the compressor is running or is it going on and off. If its is cycling on and off then you need to add freon. If the compressor is running all the time then your problem probably the blend door actuator.
Old Jul 5, 2012 | 1:55 PM
jd2350's Avatar
Thanks, I'll check that out.
samsaridinc1500
Jan 10, 2014 9:12 PM
91 silverado
Oct 27, 2007 10:46 PM
WarrenK3500
Oct 24, 2007 7:05 PM
Chestah
Oct 19, 2006 10:21 PM
jjohn82
Jun 19, 2006 12:29 AM
