ABS Light
Old Dec 27, 2010 | 6:24 PM
BDS's Avatar
BDS
Default ABS Light
My ABS light keeps coming on and off. I think its either a bad sensor or a bad wheel hub bearing. Would the abs light come on if it was the break pads or rotters or would that trigger the brake dash light? The breaks feel fine and I don't hear any noise when driving. I don't have a diagnostic scanner so I'm looking for a little insight before I replace the bearings. Thanks
Old Dec 27, 2010 | 6:56 PM
bills 98 wt1500's Avatar
pads/rotors-no. see if an auto parts store has a scanner to try or a friend at the dealer? you really should scan before replacing parts with ABS system...
Old Dec 27, 2010 | 11:48 PM
6LCHEVYZ71's Avatar
I'd get it scanned before I threw parts at it. If you're near savannah, ga I'll scan it for ya
Old Dec 29, 2010 | 12:15 PM
silverado13's Avatar
my friends 2000 does that too, when the ABS light comes on does the E brake come on too? my friends ended up being the ABS sending unit
Old Dec 29, 2010 | 12:41 PM
6LCHEVYZ71's Avatar
Code C0265
ABS Module
Old Dec 30, 2010 | 2:52 AM
that didnt answer the question about if the E brake light comes on too
Old Dec 30, 2010 | 4:21 PM
therewolf's Avatar
Hi BDS,
Welcome to the Chevy Forums.
Follow the wires by your hub bearings to the ABS sensors on your front wheels.
You may just need to rinse off the mud and snow.
Old Jan 1, 2011 | 11:58 AM
CJ_Tiz's Avatar
I had the same issue... ended up being a pinch and break in the ABS wire after I installed my lift kit. I had to splice in re rout it. Good to go now.
Old Jan 1, 2011 | 12:09 PM
ToooTall1's Avatar
Make sure you clean grounding wires and frame under drivers door outside frame looking forward. Had same problem on both my 99 and 01 silverados 4x4's. Good place to start
Old Jun 6, 2011 | 7:26 PM
tinalei's Avatar
Default abs light comes on and e brake light also
on my 1997 k1500 4x4 abs light stays on. The parking brake light just started to stay on. It makes a horrible noise when braking. Just replaced pads less than 3 months ago.. No check engine light on and no codes on code reader.
