AC problems
Old Jul 28, 2011 | 4:48 PM
  #11
ah21283's Avatar
could it be the switch board? where you turn the ac from low to high? absolutely nothing happens while turning the ****
Old Jul 28, 2011 | 4:51 PM
  #12
kevinkpk's Avatar
Until you check the motor, you will be chaseing it. If the motor is good, that eleminates most of the problem
Old Jul 28, 2011 | 5:16 PM
  #13
ah21283's Avatar
ill check it out
Old Jul 28, 2011 | 5:59 PM
  #14
ah21283's Avatar
i literaly just pulled the blower motor out, and stuck it back in and now it works on 3 and 2 but not 1,4,or 5? i guess its better than no ac in texas!!
Old Jul 28, 2011 | 6:20 PM
  #15
kevinkpk's Avatar
Yea, i am in Oklahoma, real hot. I'd suggest it is the switch.
Old Jul 29, 2011 | 9:27 AM
  #16
RacerX's Avatar
Great then it is most likely the resistor block. It is in the same place as the motor is.
Old Jul 29, 2011 | 9:54 AM
  #17
kevinkpk's Avatar
It might be, I'd suggest check the switch also. BTW what model is your 98?
Old Jul 29, 2011 | 10:36 AM
  #18
RacerX's Avatar
I dont think it is the switch. If it was the switch it wouldnt work at any speed. You get function at intermediary speeds, sounds like resistor block.
Old Jul 29, 2011 | 12:56 PM
  #19
GM Fixer's Avatar
yup...the resister block is it, also check fuse in under hood green 40 amp for the blower.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
wayne77&Trish
Sonic (Aveo)
Jun 9, 2016 12:54 AM
mwehrste
Dec 29, 2014 11:19 AM
GrayHeadedMule
Jul 9, 2013 10:16 PM
Big C
Sep 2, 2011 4:39 PM
