adding factory nav w/o bose
alright guys,
i just bought my 08 silverado crew cab w/ lt2 package. it does not have the bose option. what i want to know is can i add factory navigation without bose? i assume all im missing to have bose, is really just the center console sub???? is everything the same inside the dash s far as the wiring? i hope i gave enough information, so that i can get this answered.
thanks
Troy
thanks
Troy
RE: adding factory nav w/o bose
Yes, you can. You don't have to have the bose amp or subwoofer installed. All you need is a factory interagtion adaptor and a aftermarket 4 channel amp. The factory Nav has a seperate amp. With the adapter, you can use any 4 channel aftermarket amp. the PAC OEM-2 should do the trick. Check out the tahoe section and at the top you will see "how to add OEM Nav to your tahoe". The wiring is pretty much the same. Hope this helps
rruelas,
thank you for all your help. i have one more question regarding this. is there a particular part number i need to get for my silverado. most of the units i see on ebay, start with 15------, and the one that gmaccessories says i need starts with 29------. sorry one other question. as far as programming the unit, this can only be done via a dealer tech? again, thank you for all your help.
Troy
Troy
socaliguy81
13
September 25th, 2019 3:44 PM
rahb0sse
May 2nd, 2011 12:06 AM
spunkel1
October 12th, 2010 1:09 PM
