After I was my truck I have no power when I push on the gas!?!
Old Aug 18, 2010 | 12:07 PM
shababe's Avatar
Default After I was my truck I have no power when I push on the gas!?!
What causes my truck to have no go when I push the gas after I get done washing it. Every time this seems to happen! I go to pull out of the car wash and push on the gas and it takes a few minutes for my truck to respond! This usually continues for about 20 minutes after I continually run my truck after washing it. It is really embarrassing!
Old Aug 18, 2010 | 1:03 PM
Welcome to the forum,
what year model is your truck?
You may be getting water on the plug wires and they are cross-firing or arcing to the engine also possible the distributor cap is cracked and moisture is getting in to the cap....
may want to try spraying WD-40 on the cap and wires to see if it improves
if so it may be time for replacements...
Old Aug 19, 2010 | 2:46 AM
2wd-K5's Avatar
if it were me i would be going around the whole truck and putting dielectric grese on every wire that has to do with the engine that doesnt have a weather tite plug
Old Aug 19, 2010 | 9:18 AM
therewolf's Avatar
Hi shababe,
Welcome to the Chevy Forums.
What's the year and mileage of your truck?
I think we can all rule out a fuel problem on this one.
If you followed the above suggestions and had no success, I've got an idea which borders on the edge of ridonculous. The only reason I bring it up is that 20 minutes is about the time it would take to a paper filter element to dry with the engine running. Do you have an open air filter element or a Cold Air Intake which may be getting exposed to water when you wash your truck?
Old Aug 19, 2010 | 10:10 AM
therewolf good point or at least maybe getting partially wet and restricting full flow
Old Aug 19, 2010 | 12:06 PM
shababe's Avatar
thanks everyone for your input! I'll have to try those suggestions! My truck is a 2002 so i would hope that it's nothing very technical, but with the guy who owned it before me i'm afraid it may be! he was harsh on it!
o thanks for all the welcoming comments! greatly appreciated!
Old Aug 19, 2010 | 12:12 PM
shababe's Avatar
o and yes i have K&N Cold air intake on it! i'll take these suggests down to my dad next time i'm at his shop!
Tango72
Nov 11, 2012 1:23 PM
bens dad
Mar 8, 2008 1:59 PM
prancy
Jun 22, 2006 11:26 AM
