Air intake resonator
Old May 19, 2009 | 5:15 PM
Blindsight's Avatar
Default Air intake resonator
I was wondering; what is the purpose of the air intake resonator? Specifically, for those who don't know, the black plastic 'box' with Vortec embossed on it. I was considering removing mine and putting a secondary small filter in its place.
Also, in the air filter housing, there is a tube leading into the fender panel, which is obviously where the air comes in, but there's also a square box coming off of that tube; what is the purpose of that; would that also be another resonator? What effects should I see if I 'removed' them from the air flow?
Old May 19, 2009 | 5:17 PM
Mike Sigmond's Avatar
ROTM Coordinator
They make your engine less noisy, They take away the sucking sound & dampen the vibrations that humm, like some CAI intakes do.
Old May 19, 2009 | 6:18 PM
ukrkoz's Avatar
noise reduction for air going through. imho, slows down air flow. honestly, who would have minded it being LOUDER!!!
Old May 19, 2009 | 6:52 PM
suzuki-guy's Avatar
If you are going to remove it I would reccomend replacing it with a CAI!
Old May 19, 2009 | 7:51 PM
Blindsight's Avatar
I would definitely replace it with a CAI but I'm not in the position to buy one yet. That's my next step. Would it be okay to remove the resonator and put that small filter over the hole until I get a CAI?
Old May 19, 2009 | 7:53 PM
ROTM Coordinator
Before I got my CAI kit , I cut it off and then found a peice of plastic the size of the hole and melted it in place with a hot rod heated with my mapp gas. It sealed it up good.
Old May 20, 2009 | 1:34 AM
Blindsight's Avatar
I think I'm going to delete both of my resonators in my intake while I'm installing my throttle body spacer tomorrow. Thanks for the input guys!
Old May 20, 2009 | 2:27 PM
Blindsight's Avatar
I 'deleted' both of my intake resonators, but the bolts holding the Throttle Body were way too short to install the Throttle Body Spacer; literally, WAY too short. Any suggestions as to what this means, or what I should do?
Old May 20, 2009 | 2:52 PM
ROTM Coordinator
Ace hardware, they will have them.
Old May 20, 2009 | 3:56 PM
Blindsight's Avatar
There wasn't any way that I could see to get those bolts out; they seemed to be a part of my intake manifold. Unless I'm just being dumb. Ideas?
