Another wiper issue
Old Feb 5, 2011 | 11:59 PM
zbkeebler's Avatar
Default Another wiper issue - please help - it keeps raining
I have a 94 GMC k1500 that I recently bought and the wipers were hard wired to only work on high to bypass a bad motor pulse board and when I tried to buy a new board i found out that the motor was not the right one for the truck so i replaced the entire assembly with the correct motor and it wont turn or buzz or show any signs of life. i have taken a volt meter to the connector and all the wires show 12 volts when the switch is on as they should so I'm lost as to what to do next.
Any ideas?
Old Feb 6, 2011 | 12:53 AM
2wd-K5's Avatar
well, if theres power to it, and it isnt working you may have been sold a faulty part, one test you could do is try is to see if the ground works. turn on the wipers with the harness dissconected, make the connection between your power and ground on the connector with a test light, if it works, your ground is good and you have a faulty part
Old Feb 6, 2011 | 12:05 PM
zbkeebler's Avatar
well i tried again today and now it makes a buzzing sound all the time except for when its on high
is it possible that my switch is bad and its sending a ground to the wrong wire? can anyone tell me which wires are supposed to have power at which times?
this is what i started with
<a href="http://s175.photobucket.com/albums/w143/zbkeebler/94%20GMC%20K1500/?action=view&amp;current=IMAG0119.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w143/zbkeebler/94%20GMC%20K1500/IMAG0119.jpg" border="0" alt="Photobucket"></a>
and this is what im looking at now
<a href="http://s175.photobucket.com/albums/w143/zbkeebler/94%20GMC%20K1500/?action=view&amp;current=IMAG0122.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w143/zbkeebler/94%20GMC%20K1500/IMAG0122.jpg" border="0" alt="Photobucket"></a>
Old Feb 6, 2011 | 2:47 PM
2wd-K5's Avatar
oh, ic, are you sure you have the wires running right? i would try to find a buddy with the same truck, and look at his set-up to make sure yours is fine
Old Feb 9, 2011 | 9:20 PM
zbkeebler's Avatar
i have a new switch and motor in now so it has to be a wirinig problem...i had to run a new ground to the harness next to it
ruley73
Sep 15, 2017 8:11 AM
Chevrolaid
Astro
Jul 6, 2015 10:35 PM
Chevrolet Forum News
Jan 14, 2013 7:38 PM
PaulW
Dec 8, 2012 12:25 AM
Stimpy911
Oct 12, 2011 2:40 AM
