Bad Drive Line Vibration
Old Feb 24, 2013 | 7:24 AM
kc15's Avatar
Default Bad Drive Line Vibration
I have a 06 Chevy 2500, 4x4, 6.0, auto, that has a vibration beginning a 55mph. I have balanced the drive shaft and tried another t-case but no luck fixing it. I can jack up rear wheels and take drive shaft out and then it has no vibration. Rear end turns smooth and gears look good. Only has 72k miles. Any help would be greatly appreciated.
Old Feb 24, 2013 | 11:36 AM
is it lifted or completely stock?
where do you feel the vibration?
one piece d-shaft or 2?
have you had the tires road force balanced?
Old Feb 24, 2013 | 2:19 PM
kc15's Avatar
It's all stock.
The vibration feels worse in the t-case.
One piece recently balanced steel drive shaft with new u-joints.
Still vibrates the same with wheels & tires removed.
No vibration with driveshaft removed
Old Feb 24, 2013 | 4:50 PM
see if commanding the tcc on or off reduces or changes the vibration. If it does, follow this tsb PIP4148A
Old Feb 24, 2013 | 6:57 PM
kc15's Avatar
Ok, I probably don't have the tool to do this. The truck still vibrates at 55-60 even when I let off the throttle and put it in neutral and while coasting.
Old Feb 24, 2013 | 10:34 PM
the problem in the tsb is in the rear diff pinion gear. The tcc part is just to help id the problem.
Old Feb 25, 2013 | 6:34 AM
kc15's Avatar
Ok, Would I need a dealer to scan it. Would you think I need to re shim my rear pinion. They are some play in it.
Old Feb 25, 2013 | 9:26 AM
if i remember correctly...
backlash is not the problem its runnout. It would need crown and pinion replacement if its excessive. Its all detailed in the tsb.
Old Feb 26, 2013 | 4:47 PM
kc15's Avatar
Do you think an aluminum drive shaft would help/solve the vibration. I noticed today vibration goes away at 70-75mph. I took both axle shafts out today and still had vibration running truck on jack stands. Everything in rear end looks like new though.
Old Mar 19, 2013 | 11:31 AM
johnph's Avatar
New User
Awaiting E-mail Confirmation
im new to this site and have a question i hope someone can answer. the radio in my 08 silverado has its own way of thinking. when the weather is cold [ohio] the rear speakers only work and you cant hear the turn sig. click. weather gets warm and bingo, the front speakers work and you can hear the turn sig.click. anyone else experience this ?
