Last edit by: IB Advertising
- Chevrolet Silverado 2007-2013: What Are Signs of Bad Transmission?
Guide to diagnose trouble and recommended solutions.
Bad u Joint ??
2002 2wd
Silverado 1500 ext cab
80,000 miles
OK this is driving me nuts. About a week ago I noticed a chirping noise form the under side of my Silverado. It started off after about five minutes of driving and only at low speed. Once I pass about 20 mph I can't hear it. Now the noise is all the time at low speeds.
Today I got under the truck and everything looks fine. The driveshaft has no play at the u joints. The carrier bearing moves around a bit but not too much.
I jack the rear end up and put the stands underneath, block the front wheels, and put the truck in drive. You can hear the chrip but it is very had to pinpoint where it is coming from. I put the truck in neutral and rotated the driveshaft by hand. Now I can hear a faint chrip/squeek but it sounds like its coming from inside the transmission. My question is can the noise of a bad u joint travel down the shaft like a tuning fork and make it sound like its coming from the front of the transmission.
80,000 miles
yep, factory u-joints are ungreasable and yours are dry. the driveshaft is easy to remove and then you can inspect the u-joints and find the culprit. if one is bad do the other cause it probably has the same amount of miles on it
......It just freaked me out when I heard the noise in the transmission, but then I started to think if the vibration could travel up and down the driveshaft.
tom5170
Mar 30, 2010 1:51 PM
