Bank 1, Bank 2, whats what?
Old Sep 23, 2019 | 6:42 PM
  #11
John Town's Avatar
Default Would a bank 2 sensor 1 cause p0200 p0300 together.
Originally Posted by RonH
Bank one is the driver's side. Bank 2 is the passenger's side. Sensor one in each bank is before the cat. Sensor two is behind it.
.my scanner gives real tie reading and 3 seem similar and one has a line like erratic heartbeat does that indicate bad o2
Old Apr 17, 2021 | 10:15 PM
  #12
ChevyLifer's Avatar
Thumbs up
Don't just throw parts at it.Parts like cats and O2 sensorsare expensive. A dealer (or other mechanic) with a scantool can check your O2 sensors to accurately diagnose the problem.
If you do need to buy cats, you can find them on eBay for about $52 each with free shipping.
I found the cats for my Traverse for 225.00 for all three. The dealership I took it to did confirm the cat bank 2 was bad. So I figure, instead of getting one for 150.00, I could save a ton of cash and get all three for 225.00 from Rockauto. I have a FIXD device also and it gave the same result as the dealership did when I ran the scan using the app on my phone. I am also replacing the plugs and intake gasket all at the same time. Thins will save me close to 1200.00 had I gotten all the parts from the dealership instead of online.
Old Aug 14, 2022 | 12:22 PM
  #13
Nunnya's Avatar
Default You might wanna check first
Originally Posted by TylerWalker
thanks for the good info all. i believe that my cat is bad because of the loud buzzing noise coming from my exhaust when i'm on the gas. it sounds like a baffold broke lose and is buzzing back and forth or somthing. is that possible??
You may want to look for broken exhaust manifold bolts. Chevy has a real problem with this.
NASC3R
May 8, 2010 4:43 PM
alno1995
Mar 1, 2010 6:52 AM
tat2dup81
Sep 25, 2009 4:37 PM
Darrylw
May 27, 2008 1:58 PM
starship tahoe
Jul 23, 2007 8:48 AM
