battery question
Old Mar 9, 2008 | 11:43 PM
ronnjonn's Avatar
Default battery question
hi, i have a 91 silverado 2500 with a 350 5.7 engine 2wd. My battery recently went dead and the only battery i could find on short notice was a 550 cca. is this enough or am i going to have to buy another batter with more cc amps. It starts fine now, but im wondering if it will were down in a short time.
thanks
Old Mar 10, 2008 | 12:00 AM
northey87's Avatar
Default RE: battery question
The one in mine (same engine) has 700 CCA and 875 CA, and it has gone 2 years pass its 60 month warranty, and still going! I would think it would be enough, the battery life may be a little shorter than normal.
Old Mar 10, 2008 | 12:27 AM
ronnjonn's Avatar
i forgot to mention the one i took out was 1000ca and 875 cca, the onw i replaced it with is 650 ca 550 cca
Old Mar 10, 2008 | 8:05 AM
bluelight828's Avatar
read the owners manual to see what it recommends.
if the one you bought is working, than let it work.
depending on your climate, the battery life may be shortened.
Old Mar 10, 2008 | 8:43 AM
Jeckel707's Avatar
i would say use the other one as long as it is working for you, and as long as it is strong enough to turn the motor over and not sluggish, i agree that it may not last as long, when it dies i would say to replace it with a similar battery that you took out originally with the same CCA's
Old Mar 10, 2008 | 1:36 PM
fireman526's Avatar
I would put in exactly what you took out, if you change anything, maybe change to a better brand.
kllawson
Avalanche
Dec 22, 2010 6:31 AM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
Sirius018
Jul 17, 2010 10:10 AM
rwrows
Apr 6, 2008 12:04 PM
Louis88vette
Aug 29, 2007 11:52 PM
Top
Follow Us
