Better mph
Old Jun 18, 2011 | 7:43 AM
hondaman's Avatar
Default Better mph
I have a 01 silverado z71 package 130000 miles I got it back in December mpg is about 15 I have a borla catback on it. What can be done to improve mpg?
Old Jun 18, 2011 | 8:42 AM
stew160's Avatar
Have you changed the air filter and cleaned the intake recently? Worked wonders on mine.
Old Jun 18, 2011 | 8:57 AM
hondaman's Avatar
What do you mean clean the intake?
Old Jun 18, 2011 | 3:42 PM
country_09's Avatar
new air filter will help a little bit, airaid jr. intake tube will help more, and a custom tune will help the most. went from 12.5 to 16 on my last tank and I've done all these mods. but also you can't drive like a bat out of hell and expect to get good gas mileage
Old Jun 18, 2011 | 7:08 PM
stew160's Avatar
Default Cleaning the carb intake
Engine not running. Remove the lid from the filter housing and loosen what appears to be a large hose clamp on the carb. The large air filter housing hose will slide off the carb. Place a rag under neth the throat opening to catch overflow. You will then use the aerosol cleaner to spray into the throat of the carb. and watch for all the grime to begin to flush out. Avoid hitting ant electric sensors directly. Some wiping with a clean rag will help. Operate the throttle with your hand clean the butterfly valve area in the carb throat. You will be amazed at the amount of grime that will come out of there if never done before. Put it all back together with a new air filter and your done. That is the general idea. You should find similiar directions on the can. It is intake cleaner not carb cleaner.
Mechanics will charge $100 to do this simple procedure. I have done this several times after learning how much it helps. I initially learned it after my wifes Yukon XL began bogging down at take offs. This crured it. May help your situation. It is worth a try.
Hope this helps! Alot of words for such a simple procedure. Potential big pay-off in mpg. Increased my Z71 from 14 back about 17mpg.
Old Jun 19, 2011 | 7:20 AM
stew160's Avatar
Sorry, I meant throttle body not carb in the previous post. By the way what is a borla catback?
Old Jun 19, 2011 | 9:43 AM
country_09's Avatar
Borla catback is a full Borla exhaust from the cats back...not just puttin the muffler in place of yours and callin it a day
Old Jun 19, 2011 | 9:57 AM
stew160's Avatar
Gotcha! Thanks country 09
96 chev
Mar 19, 2008 11:54 AM
tobyw
Nov 12, 2007 6:45 PM
spike1master
Avalanche
Jun 23, 2007 5:32 PM
amos221
Jan 21, 2007 11:04 PM
chevvy2000
Oct 9, 2006 11:26 PM
