Bleeding ABS brakes after overhaul?
2001 Chevy Z71 4x4, had to change out all the corroded brake lines.
Since the abs module was left open while we made connections, HOW do I bleed these things.
1. normal and maybe it will work?
2. see if there is an open port/valve or screw on the abs modulator.
3. Rent a scan tool to set the valves open in the modulator?
4 Some other Trick in someones bag that wouldn't mind sharing?
thanks alot
thanks alot
KevinCarter
September 21st, 2008 4:54 AM
